Thundercat master cylinder.
Hi, can I use a thundercat front master cylinder with my oem brakes and how do you mount the reservoir. I have done a search but could not find an answer.1990 FZR 600 four pot brakes.
1990 FZR 600 GENESIS.
1986 SUZUKI DR125S.
1992 SUZUKI DR 250S.
1986 SUZUKI DR125S.
Re: Thundercat master cylinder.
Yes, you can. It's definitely an upgrade from the standard master. An even better upgrade would be a 16mm radial master (can be found on later R6's). Mounting? There's a numerous creative ways to do it but I like this way:
Thanks for your reply, basically I need to replace my master cylinder and can get yzf one cheaper and Ilike the reservoir design better for filling ( ex rd owner!). Bike on a rolling restoration as and when I get work at the moment so budget is tight. Bob.
1986 SUZUKI DR125S.
1986 SUZUKI DR125S.
Have managed to fit thundercat master cylinder while retaining mirror stay by using a lower profile reservoir and bracket mounted from top yoke by using the screw threads at the end of the top fork clamp. Used a bit of threaded rod and made a spacer to slide over part way to get clearance for locknut. You could use t/cat reservoir but I have a better view of the temp gauge and warning lights with the shorter res.
1986 SUZUKI DR125S.
1986 SUZUKI DR125S.
rabbit57 wrote:Have managed to fit thundercat master cylinder while retaining mirror stay by using a lower profile reservoir and bracket mounted from top yoke by using the screw threads at the end of the top fork clamp. Used a bit of threaded rod and made a spacer to slide over part way to get clearance for locknut. You could use t/cat reservoir but I have a better view of the temp gauge and warning lights with the shorter res.
