how many rpms before you shift gears?
im confused on when i should shift gears in my 95 yamaha fzr. when should i shift from first to second, and second and third, so on and so forth, etc?
Re: how many rpms before you shift gears?
It depends on where and how you're riding. Just puddling around town on a cracked throttle you might shift at 7 or 8k. If you're absolutely caning it you want to shift closer to 11k. It also depends on your mood - I've trickled through slow traffic in first while turning over 17k, just to watch the heads snap around looking for this unholy SHRIEK!
- kilika2
- 1000+ Posts
Just shift some time before the red bar. Jk. Seriously though just like Don said just shift when you want as a general rule of thumb keep it above 3k.
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
JasonRDfan
If I'm slowly accelerating through town I change around 3,500. Pulling out of side road 5,000 If I'm on an on ramp 7 to 8 thousand if I'm running hard 11,500 to 12,000.
Yeah I mean I usually shift at like 4k around, just riding around
