hey guys I just got my first bike and it is a 91 fzr 600.... I need to know how to sync th carbs the right way and I do have the carb sync tool so I do not have to make one.... im not a super good diy mechanic but I can usually figure it out but the more its dumbed down the easier it is... im also a visual learner so pictures help more than words generally
and also when I got the bike there was a large amount of gas in the oil so I changed the oil and the guy I bought it from said that the carbs needed cleaned and that it was probably a stuck float or needle and once I took the carbs apart none of the floats or needles were stuck but I cleaned it all up anyway.... does any body know what may have caused that to happen???
carb sync
mossyoakboy
carb sync
Combat Engineers, Shaping the Battlefield one explosion at a time!!
bike: '91 fzr600
cage: '99 f150
bike: '91 fzr600
cage: '99 f150
Re: carb sync
mossyoakboy
Re: carb sync
ive checked that page more than once... and most of the guys are using homemade carb syncs but I actually have the Carbtune Pro system and I have never used it ... its my dads but he is letting me barrow it. is there somewhere on here that talks about how to use this particular system or one close to it??
bike: '91 fzr600
cage: '99 f150
bike: '91 fzr600
cage: '99 f150
- GreyImport
Re: carb sync
https://www.youtube.com/results?search_ ... .0.0...1ac.
https://www.youtube.com/results?search_ ... xORiLFyqIY
1990 FZR250R 3LN1
http://2fiftycc.com/index.php
LiteTek Carburettor Seal Kits
mossyoakboy
Re: carb sync
does the screw connect to the bottom of the carb and the bowl outline go around it, cause if so then I think I found it or is it one the bottom of the bowl itself??
bike: '91 fzr600
cage: '99 f150
bike: '91 fzr600
cage: '99 f150
- GreyImport
Re: carb sync
1990 FZR250R 3LN1
- GreyImport
Re: carb sync
Something like this......take out the screw and screw in the carb tune adapter ..... hopefully u have a Yamaha set.
1990 FZR250R 3LN1
mossyoakboy
Re: carb sync
thank you so much for the picture that made it perfectly clear.... I will let you guys know who it went later next week... I got drill this weekend so im not gonna be turnin any wrenches for a few days but thanks again guys
bike: '91 fzr600
cage: '99 f150
bike: '91 fzr600
cage: '99 f150
