Carb diaphagms
Carb diaphagms
I have been looking for replacement diaphragms this afternoon cause the last person in the set of carbs on this bike pinched 3 out of 4 and one is completely toast. I don't want to buy the whole slide assembly just would like to instal new rubbers on the slides. Anyone can help I would appreciate a hand with this.
- willandrip
- Level 7.0
Re: Carb diaphagms
Rooster,you dont say which model you have but this may be of some help;
http://webcache.googleusercontent.com/s ... clnk&gl=uk
Re: Carb diaphagms
I have a 3GM according to the side of the carbs themselves but I have no idea what that means when it comes to the mikuni #'s but I will do what I can to figure it out and take advantage of the info on that link I hope.
Re: Carb diaphagms
If it be true that the 3GM carburetor was in FZR1000's from 89-95 then that makes the Mikuni number a BDST38 and if that is also true then the carb diaphragm from a 93' DR650 will work according to the link. I can get them locally for $39 each.
- willandrip
- Level 7.0
Re: Carb diaphagms
And if all the above be true; a saving of $200 per carb by my calculations.!
Please let us know the outcome, Rooster.
- GreyImport
Re: Carb diaphagms
1990 FZR250R 3LN1
http://2fiftycc.com/index.php
LiteTek Carburettor Seal Kits
Re: Carb diaphagms
willandrip wrote:And if all the above be true; a saving of $200 per carb by my calculations.!
I've also had this confirmed previously some time ago so added it to the carb section over at my place
http://www.exup1000.co.uk/tech_info_are ... ntoobs.htm
