Wet exhaust help!
Wet exhaust help!
I purchased a FZR600 and it already had the exhaust valve (evap i think?) removed. I opened it up to have a look inside and the header on the far right has signs of fuel in the pipe. What could cause this, valves, shims?
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
Re: Wet exhaust help!
Could be that the carb float valve is sticking open or isn't seating properly allowing fuel to leak through.
Thanks man, i just cleaned the carbs, maby ill just go get my carbs tuned!
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
