Hi, folks.
After a long hiatus, I'm trying again with the electronics. I am looking for an owner of a FZR1000 to test my re-try of the EXUP eliminator. This will convince the TCI that there is actually a working EXUP servo attached, and will prevent it from cutting in a rev limiter at 4k rpm.
While the circuit should work on all years of EXUP-equipped 1ks, I have only been able to source the connector for the rectangular 6-pin version. If your TCI looks like this, I'd appreciate your help:
If you have the older round connector, I might be able to help you later - but I want to get this tested first!
Please contact me via PM if interested. I will send you two devices to test. In return, I will also send a production model (weather tight and compact) once they're ready.
EXUP Eliminator - Beta Tester Wanted
Re: EXUP Eliminator - Beta Tester Wanted
That about sums it up...I'm curious to see this work.
Do I hear a volunteer?
PM your address, and I'll pop the prototype in the mail tomorrow.
I've got a 91 with a 1040 kit in it. Still working on getting some carb parts. Once I get it up and running ill message u if u haven't gotten a guinne pig yet.
