I have 95 fzr 600 fox eye, my query is, my brake light works when I press front brake but not when I use back brake, any ideas? Is this normal and is it an MOT fail?
Any suggests would be greatly appreciated
Brake light doesn't work
BigSte987 - 95 FZR Foxeye
Redoliander
Behind the foot brake lever there should be a spring that connects to the light switch. If the spring is connected then the switch needs to be adjusted. There are two nuts on top and below the bracket. Unscrew the bottom one a bit then screw the top one to tighten it back down and check if its working.
- GreyImport
Re: Brake light doesn't work
It will look something like this.....dont forget to make sure its plugged into the harness
1990 FZR250R 3LN1
http://2fiftycc.com/index.php
LiteTek Carburettor Seal Kits
Yeah, these things are annoying - if they aren't NOT working, they like to jam ON, so you still have no effective brake signal ... Give the little plunger in the middle (at the end of the spring) a spritz of WD40 when you get in there, keep things moving nicely.
Just to let you all know, I adjusted it and it worked, thanks for your help
- KillerCobra
I have the same issue but reverse. Light works on pedal but not front lever. Any typical causes? I also have a single 7" headlight the PO installed. Could this have anything to do with it? I'm new to bikes so I don't really know where to start. Any suggestions?
1999 Ford SVT Cobra
1997 Yamaha FZR600R
1997 Yamaha FZR600R
The front switch itself rarely fails, but is vulnerable to having the push-on connectors yanked off. Make sure the silly thing is still plugged in!
- KillerCobra
OK I'll check that when I get home and report back. Thanks.
1999 Ford SVT Cobra
1997 Yamaha FZR600R
1997 Yamaha FZR600R
