As you know, whilst I have been working on the starting issues I have been looking at some other essential work the bike needs.
When I first took the bike out for a short ride it started running really rough and the revs wouldn't drop. It eventually conked out and I walked it home. It wasn't until I got home that I realised the grip had worked it's way down the throttle body and onto the bar end. I slid the grip back up the bar and it started straight away. So, I've been planning to replace the grips.
I bought these the other day and they arrived this week:
http://www.ebay.co.uk/itm/130769448261? ... EBIDX%3AIT
But when it came to fitting them I was presented with a bit of a problem. The throttle side bar end has no socket in it for an Allen key whilst the clutch side does!
So I assumed that it must still screw out and I went and found some of my most commonly used tools...
But it was to no avail. Now I'm wondering if it is possible to remove the throttle assembly from the other end of the clip on somehow? Has anyone else found this to be an issue? Should I just keep hitting it?
Anyway, in frustration I moved on to the next job. Removing the radiator to allow easier access to the spark plugs for a switcheroo... I had heard that you can just remove the side mounts and let it hang there and get good access to the plugs, rather than having to empty the rad itself so that's what I tried next.
It would appear that I don't have enough slack in the rad pipes for the top rubber to clear the mount so I'm going to have to drain the rad anyway.
Quick question: Can anyone explain the purpose of the rad water tank at the back of the bike (under the fairing). Is this an overflow or should it be kept full? It looks lower than the top of the rad so I can't see what it achieves...
