Hydraulic Clutch Conversion Basics - Write-up Added
Re: Hydraulic Clutch Conversion Basics - Write-up Added
trifgeorge wrote:I got it george. but what if i shorten the spring that is inside? wouldn't that make it squirt out more liquid?
TG,
Lengthening the actual stroke will help BUT watch out for the return & feed holes and the length apart still working, maybe a shortened piston itself ??????
trifgeorge
Post by trifgeorge »
TG,
ok.switched the slave cylinder with a smaller scooter single cylinder caliper, made a mounting plate and .....it works...sort of. the clutch disengages as soon as i pull in the clutch handle (only needs 1 cm of pull). but the wheel does not move as freely as when the bike is in neutral. is this normal? and the cluch is hard to pull (compared to when the fzr 1000 slave cylinder was used)
Picture with the lenghtened push rod
Picture with the scooter caliper as slave cylinder.
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
trifgeorge
got a video up to show you how the rear wheel moves in the first gear.
http://www.youtube.com/watch?v=XwGqUZAXfno
R6 pilot seat
KOSO mirrors
H1 HID
TG
now you see what I mean by:-
"The handlebar lever bore & the slave cylinder bore work like gear ratio's in this respect."
trifgeorge
TG
YG,
Yes, I undestand now. :cheers:
But is one thing that I don't understand. The amount of movement that this slave cylinder is making looks the same as the fzr 1000 one did, and still this one disengages the clutch. And one more question, do you think it's ok for the wheel to spin as hard as is with the clutch pulled in. With the clutch full in, you have to push it a little bit harder at first to make it spin, but as soon as you move it a bit it spins more freely. Also if you keep the clutch pulled in and stop spinning the wheel and then you start spinning it again, it will more freely at the first move as well. Is this good or is this bad?
R6 pilot seat
KOSO mirrors
H1 HID
mrfreeze5
Level 8.0
Level 8.0
Post by mrfreeze5 »
Has the bike been sitting for a while? Sometimes it can bind up a little and stick when its been sitting, and once you break it loose everything kinda drags. Once the bike is started and the oil is moving, and the output shaft spins a few times, it looses up.
trifgeorge
Yes, it has been sitting since September, but i started it like a month ago, but the temp outside and in my garage get as low as -17 C, even lower, and i have 15w50 oil into it.
R6 pilot seat
KOSO mirrors
H1 HID
trifgeorge wrote:Yes, it has been sitting since September, but i started it like a month ago, but the temp outside and in my garage get as low as -17 C, even lower, and i have 15w50 oil into it.
TG,
that sounds like oil drag as it is so cold & sticky.When i had to deal with cold auto's I used a lamp to keep the engine block warmer and the oil from getting almost like varnish/treacle
trifgeorge
YG,
That calmed me down a bit. Thanks!
R6 pilot seat
KOSO mirrors
H1 HID
