!!!!!!!!GHETTO'S BIKE BUILD!!!!!!!! new pics up
Re: Ghetto bike build(look r6 swingarm pics)
my zx6rr sprocket came from ebay and was about $20. I dont remember the seller though. I want to say it was along the lines of sum of all parts...
- ghettomedic505
and the year is 03-06 ish rightmrfreeze5 wrote:my zx6rr sprocket came from ebay and was about $20. I dont remember the seller though. I want to say it was along the lines of sum of all parts...
OH I THINK I DROPPED MY MONKEY
crap, I dont remember...
That sounds about right though...
- ghettomedic505
Re: Ghetto bike build>update need help
So i got the yzf tank in and need a mlittle help. if you an please take pics of how you mounted it and post. thanks in advance
Front or back?ghettomedic505 wrote:So i got the yzf tank in and need a mlittle help. if you an please take pics of how you mounted it and post. thanks in advance
- ghettomedic505
the back please but if you have the front it wouldnt hurt and Im going to have totrim the r1 seat like you did freeze. it doesnt fit right
ghettomedic505 wrote:the back please but if you have the front it wouldnt hurt and Im going to have totrim the r1 seat like you did freeze. it doesnt fit right
Yeah i had to trim my seat pan at the outermost tips because the radius is tighter on teh R1.
the BEST way to mount the front is to use the front bracket from a FZR1000. It is completely bolt on and fits perfectly. you can buy it new from bikebandit or the dealer.
Anoter option is to bend and modify the stock front FZR bracket, but I think this looks like ass and doesnt fit that well.
Since youre still using the stock subframe there are limited options. There is a way to modify the stock rear bracket to fit, but I never tried that so I dont know specifically.
Before I decided to cut off my stock subframe(because I HATED the way teh R1 tail fit it, just did not look right and no good way to fasten the passenger seat, and the undertail didnt look right with it. The tail was too flat) I reused what I had available. My bike came with FZR1000 fairings and tank on it and it had the FZR1000 rear bracket on it. i cut it and rebent it and was going to rivet it to the frame, but it seemed too halfassed for me.
Check this page out, it documents my first attempt at this setup. i did not like the results with the rear tank mount or the tail orientation, plus I wanted to safely carry a passenger and eventually decided to do the undertail exhaust, so the new subframe became the best alternative. I still have the front bracket and it could not fit better. The only modification I made to it was to drill a new hole on the tank side bracket for the horizontal mounting bolt to allow it to slide forward about 5mm and a little lower to allow the tank to sit more flush with the frame. It made a big difference in the way the tank fit.
http://www.fzrarchives.com/ipb/index.ph ... 1279&st=30
Now, to mount the rear of the tank to the subframe, I drilled to holes, one on either side along the edge of the tank. I also drilled a matching hole in the raised lip along the side of the subframe on the top and tapped it. I now use to 6mm bolts to bolt the tank directly to the subframe with a small rubber washer in between.
actually, just follow the link in my sig, its already got these pics and more. Its not quite comprehensive, but it gives you soem options.
- ghettomedic505
SO I DECIDED IM GOING TO JUST FAB A MOUNT UP SOME HOW, WONT BE PRETTY BUT WILL WORK. ALSO GOT THE FRAME WELDED WHERE I GROUND DOWN TO FIT THE SWINGER(PICS IN THE MORNING) SO i JUST NEED TO FIT THE TANK AND TAIL WAIT FOR MY SHOCK BRACKET TO MOUNT. THEN ITS PAINT, PUTBACK TOGETHER, AND THEN ITS DONE.......FOR NOW
Re: GHETTO'S BIKE BUILD
you can modify the stock bracket to work. Its not pretty though. If you can weld, it wouldnt be too difficult to make a bracket yourself that mimics the 1000 piece.
Some rectangular tubing, a little bit of plate and a little time is all you need.
- ghettomedic505
So its been way to long since I posted an update or even worked on the bike. I just had a crazy last month abd didnt feel much like working on the fizz but I pulled my head out my a$$ and here is a pic for ya all
Looking good mang...looking good.
- megaloxana
Build it...Ride it
- ghettomedic505
so question look at above pic and tell me if that is how the dog bone and shock is suppossed to go. also for those who have done the swao is it supposed to be really stiff???? or did i do something wrong
- tampaFZR600
- Level 4.0
damn those primer pictures look quite familiar!
Are you going to paint the frame Black?
