New Coils, leads and plug caps. Now won't start
buzzawak
Re: New Coils, leads and plug caps. Now won't start
Post by buzzawak »
If you have something solid causing a blockage sonic cleaning may not do it. You have to inspect each channel using compressed air and a length of wire.
I am have asked you this but how are you emulation tubes?
chris-seed
Post by chris-seed »
That's a good point. I haven't clean anything out with air or wire. I did take the carbs apart completely though. So all of the jets and emulsion tubes came out and got cleaned individually. I then sprayed carb cleaner through everything.
I haven't fully checked the emulsion tubes. They're all intact, but I'm not sure if any of them are deformed or not.
Rayman
Post by Rayman »
treid new plugs and synched the carbs -
mine started fine after an engine swap -
went away for two weeks came back - just coulnt get it to run - not even on ether -
went and got new plugs - old ones turned otu to be very sooty- ( came i nthe swapped engine)
first press of the starter - away she went.
Rayman
Ignition Modules and other stuff
www.rae-san.com
cx500A - grey - commuter (phantom) SOLD
cx500B+ - undertail exhaust - complete (Storm) SOLD
vf750f - complete but needs a repaint and rings
vf750s - complete - sold
vf750s - fiddler - vf1000f forks, ignition trail, 4into1, pods, clip ons, dual headlights etc
next cx - cx500 in 650 frame with undertail pipes and lots of changes - almost done
91 - fzr600 New project
