The thing to look at are the plugs. I'm 95% sure that if the VR uses a 5 wire terminal connector (Yamaha brand only) that you can use it. The FZR/YZF/R6 VR's were all the same once they switched to the 5 wire models. I think the R1 is different but I'm not sure on that.yamaha_george wrote:95FZR600 wrote:On a 95 Fzr a yzf VR can be used for direct plug in? Yamaha george??? Has anyone confirmed this?never worked on YZF's
1998 rectifier and regulator with 1992 harness
Re: 1998 rectifier and regulator with 1992 harness
