Where to drill on YZF motor for Speed sensor?
Genesis
Level 8.0
Level 8.0
Re: Where to drill on YZF motor for Speed sensor?
Post by Genesis »
pefrey wrote:Perhaps this is a dumb question, but a speed sensor for what? Are you installing a different set of gauges?
r6/ r1 gauge swap.
My FZR6 Rebuild
shredex
Post by shredex »
well, drilled it...fooked up. drilled about 1/8" to far to the right and down...I think its a shift fork that im looking at.
my sensor is about a half inch to long. so gotta make a weird shapped spacer that will point the sensor up a bit to miss the shift fork and so it doesnt hit.
anyone know how close the sensor has to be to the gear?
Genesis
Level 8.0
Level 8.0
Post by Genesis »
I have an extra cut washer template you can have machinist make an aluminum version of, I will send you, if you promise to mail it back. It has the outside dims, you just have to have the machinist make the center hole to match your sensor, and it will save you from tiring to figure it out.
My FZR6 Rebuild
shredex
Post by shredex »
yea, but, i dont need a washer, its more of a spacer because I need about a half inch of something added inbetween the sensor mount and case
Genesis
Level 8.0
Level 8.0
Post by Genesis »
shredex wrote:yea, but, i dont need a washer, its more of a spacer because I need about a half inch of something added inbetween the sensor mount and case
Wow a half inch? the plate, at least my plate does not set flat against the case.
My FZR6 Rebuild
shredex
Post by shredex »
yea, just about a half inch but its not going to be even because i gotta angle the sensor up. so its going to be 1/2" on one side, and like 1/4" on the other
haro504
Level 7.5
Level 7.5
Post by haro504 »
did you ever find a pic of where to dril the hole if not why dont you throw one up so we know where its supposed to go
(think of the children)
shredex
Post by shredex »
95FZR600 wrote:Shred, which sensor did you go with? Did you look to see what I posted on the WIKI about the differences in sensor lengths?
all I know is that the sensor says "toyota" and a bunch of different numbers on it...
Gen. I used the picture you posted on the first page of this thread as my guide since it was on a yzf motor
Genesis
Level 8.0
Level 8.0
Post by Genesis »
shredex wrote:Gen. I used the picture you posted on the first page of this thread as my guide since it was on a yzf motor
glad it worked out. pm me if you want the plate.
My FZR6 Rebuild
