pilot jet is for the choke
once you close the choke it moves to the main jet...you might also have your main and pilot switched and that could be causing the problem...mine were switched in my first carb and I had running problems then
I need help!!
Re: I need help!!
When i open the carbs up, is there anything else you think i should look at to see if its clogged? I took the mixture screws out to about 3.5 turns. there's just a lot of inconsistency in the vacuum pressure. They are all different depending on the RPMs. No matter what i adjust, it still sounds like a V-twin
. Alright, i'm going to look into taking the carbs out.
- shredex
Re: I need help!!
mine sounds like a v-twin right now because my ignition coils suck
when you open the carbs, check to make sure all your floats are at the same height and that none of them are stuck.
Re: I need help!!
Pilot jet is for idling, not choke.
Re: I need help!!
Thanks guys. I'm going to open it up tomorrow and repost what i find.
