I need clutch HELP!
mossy1200
Level 5.0
Level 5.0
Re: I need clutch HELP!
Post by mossy1200 »
AR91RX wrote:I’m not totally familial with the term fibres, I’m assuming you are talking about the clutch discs though. Yes they are reused discs, as for the free play there is like almost none. I’m defiantly going to go check that all the steels are facing the same way, they should be because I never separated them when I took them off. I kept everything together the same way if came off reinstalling it the same way. Never hurts to double check though.
-Thanks, Andrew
Assuming you had clutch problems prior best to check that the last person did them correctly.Fibres are the pads between each steel.
Soak them in the same oil that you run in bike for 1/2hr plus before reasembly.If they are totaly dry they give problems.
AR91RX
Post by AR91RX »
I was not having any cluth problems before I had to make this fix. But the bike has been sitting for more than two months without oil so everything in there is bone dry. Tomorrow morning that is first thing i'm gonna do.
-Thanks and lets hope this is the problem.
97' FZR600 Blue/white, Vortex 520 chain/sprockets, V&H SSR2 Exhaust.
