why i like Yamaha...
the_finch
Level 8.5
Level 8.5
Re: why i like Yamaha...
Post by the_finch »
reelrazor wrote:Our FZRs have TCI ignitions. This is essentially a solid state 'kettering type' ignition. The coils have full time 12vdc to saturate them, and the ignitor box switches the 12vdc off when a spark event is needed. The primary coil field collapse induces the secondary coil to spark the plug. (this is distinct from a CDI system in which the ignition primary is fired by a high voltage(100-300vdc) pulse from triggered capacitors which induces a stepped up pulse in the secondary coil to fire the plug)
I thought that only the 1989 to (approx) 1991 600's had the old style ignition, and that the newer ones (like my 97 FZR600) had the CDI-style ignitions.
Only reason I say this is because I seem to remember there being some big difference when buying aftermarket coils for the early vs. late vs. Vance & Hines Special Edition FZR600's. canofworms
1997 FZR600RJ
match417
Level 8.0
Level 8.0
Post by match417 »
the r6 coils won't work unless the coil has 3 prongs, one for power, one for signal and one for ground, but the r6 coils only have two prongs, one is ground, the other is signal. i've been thinking about it all day. and my relay idea won't work unless the relay is capable of opening and closing extremely fast. the only way to do it would be to get a separate CDI and wire it directly from the pickup coil. it might be possible to get the r6 ecu, and wire it in for use on the FZR, just not connect the injectors and all of the other sensors, not sure if that would work though, oh well..
bucket,
I'm not using a stock ecu. I'm a tuner on the side, well, i was..i have an autronic sm4 and an AEM C2DI as my CDI. I'm going to put a turbo in that pushes the engine to the max almost. I'm trying to fine a GT3071R or GT3076R, i saw one a few months ago on craigslist Socal, $400 and it needed a rebuild, i just didn't have the cash to get it. I would have loved to get that thing for $400 and then rebuild it.
My old engine was a stock 5sfe, non-turbo..slow..underpowered..this is the NEW celica
I have at least 8 grand in parts in the engine..this is the stuff that I can think off right now..
Autronic SM4, made my own harness, 640volt AEM C2DI
TRD clutch kit, fidanza flywheel, stock 5sfe trans for as long as it holds..haha
knife-edged crank, with crank scrapers under the main caps
JN pistons, eagle rods
sard 850cc injectors, wolfkatz custom fuelrail, walbro 255lph fuel pump.
R6 c.o.p.'s NKG iridium plugs IK24
5sfe pulley and brackets from my old engine
head has 10k miles(got it from Joel at toysport), block has 40k, when i took the block apart there were still numbers on the crank where it sits on the main bearings (the guy at the machine shop said he had never seen that either, they usually wear off by the time an engine needs machine work
I sold Joel at toysport the transmission from the 3s. It would have been a mean tranny, but i'm getting an AWD one when my stock one breaks..considering i have the money to even get it going again.
HKS cams, 272 degrees and 10.2/10.5 mm lifts, AEM true time cam sprockets, stock timing belt
Me and Joel tested the stock springs, compared to the stock turbo ones, and dual coil ferrea springs..stock ones had the best tension.
My valves are 1mm overbore ferrea.
I still have the stock turbo mani, blitz downpipe, really fat intercooler by turboxs (its from a nissan s14/s15). me and my friend custom made a bracket and replaced the bumper reinforcement with it, the intercooler sits inside of it..
match417
Level 8.0
Level 8.0
Post by match417 »
the_finch wrote:I thought that only the 1989 to (approx) 1991 600's had the old style ignition, and that the newer ones (like my 97 FZR600) had the CDI-style ignitions.
I'm not arguing with you, but if there were a change like that wouldnt there be a different wiring diagram? I have the book and it only shows one wiring diagram for the US FZR600's.
the_finch
Level 8.5
Level 8.5
Post by the_finch »
With the differences you mentioned, it sure sounds like there should be a huge difference in the wiring. But I honestly could not tell you, as ignitions have always sort of been like a type of unknown black magic to me. I understand a little from the muscle car world, such as some of them have a coil per cylinder, some only have one coil, and there are some that are mechanically timed and advanced and some are computer controlled.
(This is usually the part where Yamaha_George or RageDigital chime in out of nowhere with the correct answer and a bit of little known trivia) :whistle
1997 FZR600RJ
reelrazor
Wrench
Wrench
Post by reelrazor »
Mine's a '96 and it has a TCI box. Says right on it, Yamaha Transistor Control Ignitor. According to The YMC online microfiche, the ignitor is the same part number from '89-99 (3HE-82305-00-00) .
the_finch
Level 8.5
Level 8.5
Post by the_finch »
reelrazor wrote:Mine's a '96 and it has a TCI box. Says right on it, Yamaha Transistor Control Ignitor. According to The YMC online microfiche, the ignitor is the same part number from '89-99 (3HE-82305-00-00) .
Thanks for clarifying that. So if I'm gonna replace the coils with some that are hotter, like a Subaru Coil pack or one from a newer bike, then I need to go with non-CDI coils, right?
1997 FZR600RJ
reelrazor
Wrench
Wrench
Post by reelrazor »
Yes, correct.
I am researching this whole idea. Thee nissan c-o-p units actually have the transistor circuits built in-so therefore have too high impedence for our ignitors. (Some) Ford 4.6 V8s use c-o-p inductively. Accel replacements are $30 per or you can buy sets of 8 for a discounted price. I have one of those accel coils coming for tomorrow so I can test it.
bucket
100+ Posts
100+ Posts
Post by bucket »
I would go with a 2nd gen motor for big HP less head porting and I think there was some odd ball problem with the materials they make the 3rd gen blocks out of. Its been a while sence Ive looked in to 3s motors. I heard a guy was running a 3s in a pikes peak race car. pulled a 1200hp run on the dyno... then detuned it to 900hp so he could drive the car.
Im still a bit of a tunner...
