bike starts in all gears now.
Dragon
Level 2.5
Level 2.5
Re: bike starts in all gears now.
Post by Dragon »
shredex wrote:
megaloxana wrote:It sounds like you're not running on all 4 cylinders. I dunno if thats just how the audio came out to be, but it would explain your stalling issue. Try replacing or cleaning the plugs. And make sure you're getting spark on all 4. (note* if you're check for spark by grounding the electrode against the engine, make sure the other 3 plugs are grounded aswell, preferably screwed into the head)
the plug on the 3rd head is loose, I brought it to a guy today. he hooked it back up and it sounded great. but its still loose so it cuts sometimes. I dont know if I should put some electrical tape on there to hole the tube in.
Just pull the tube out the boot at the plug and cut a 1/4 inch off of it. Push it back in the boot really good,reinstall & that should work.
shredex
Post by shredex »
ill try this tomorrow. It works pretty good as it is now, but sometimes it kinda cuts out. so Ill do as you meantioned and ill also put electrical tape around it.
ps. it very hard getting my hands inside the frame to reach the damn 3rd plug.
megaloxana
Post by megaloxana »
Yeah i have to take my bodywork off and then I drop the radiator to get to the plugs.
shredex
Post by shredex »
Dragon wrote:Agreed on what Mega said about your bike running on 3 cylinders. Do as stated by Mega. Seems to me you're afraid to take off. :rofl: As you were taking off, I didn't really hear the engine like you were giving it some gas until the bike was actually pulling you from the stand still. Check the plugs, see if you're getting spark and work,work,work on your take off!!! :thumbsup: You may want to invest in a Haynes manual if you don't already have one. Check Ebay, they are about $30.
my bike will shut off if I give it to much gas, I have to be EXTRA careful with it.
i tryed giving it more gas when I was holding up traffic but it didnt help. I have to do it really slowly.
but the guy I brought my bike to said I almost had my clutch adjusted perfectly. im missing the spacer piece to my clutch handle though which the guy noticed, so I had him order me a new one for $8.
shredex
Post by shredex »
megaloxana wrote: Yeah i have to take my bodywork off and then I drop the radiator to get to the plugs.
do you drain the radiator before you take it off? or do you just unbolt it and let it hang while you get the plug?
megaloxana
Unbolt and let hang
Dragon
Level 2.5
Level 2.5
Post by Dragon »
??? What spacer piece? :jawdrop: The piece that adjust the cable at the lever? I would like to see that piece when you get it installed.
shredex
Post by shredex »
its just the gold piece here I have circled in green. my clutch is missing it so it flops
Dragon
Level 2.5
Level 2.5
Post by Dragon »
Ok, now I understand.
