FZR400 Stator
FZR400 Forum
SubyRS
Re: FZR400 Stator
Post by SubyRS »
I may have an extra stator for my FZR400. I'll check through my boxes and post back......
This the the puller I got from Yamaha 8 years ago. You can just buy a case hardened bolt with the same metric thread and just grind the end perfectly flat.
Just make sure you use an impact wrench to drive the bolt and the stator literally should pop off.
My 1989 FZR400 (restored)
SubyRS
Re: FZR400 Stator
Post by SubyRS »
Yup I have a FZR400 stator. If you are in So. Cal you are in luck : )
Still protective wrapped.
Re: FZR400 Stator
SubyRS wrote:Just make sure you use an impact wrench to drive the bolt and the stator literally should pop off.
NO, don't use an impact driver! This can damage the internal threads, or skid the journal surfaces on un-pumped bearing shells. Tighten the bolt / puller in firmly without really torquing it, then give the end of the bolt a smack with a rubber mallet. As you say, it should just pop off. If you don't have a rubber mallet, a ball-peen hammer or other implement of destruction CAN be used, but you MUST use a wooden block between the hammer and bolt.
Scrappy34
Re: FZR400 Stator
Post by Scrappy34 »
SubyRS wrote:Yup I have a FZR400 stator. If you are in So. Cal you are in luck : )
Damn, too bad I'm across the country. How much would you want for it? Price+shipping? I'm in Gaithersburg, MD.
Evilchicken0
Level 3.5
Level 3.5
Re: FZR400 Stator
Post by Evilchicken0 »
Just as an aside this is the flywheel and alternator for the later 3TJ model
It makes changing the alternator a lot easier
FZR400RR 3TJ Bimota SB6
SubyRS
Re: FZR400 Stator
Post by SubyRS »
Scrappy34, PM me on the stator. I tried to PM you but it says your name does not exist.
Sorry didn't see your post. Been re-restioring my own 400 this last month : )))
