Gasket Kit
FZR400 Forum
snydes
100+ Posts
100+ Posts
Re: Gasket Kit
Post by snydes »
I don't understand any of those names really, and it turns out a few gaskets from the one I ordered don't fit
Sent from my Nexus 4 using Tapatalk
Thanks,
ASnyder
willandrip
Level 7.0
Level 7.0
Re: Gasket Kit
Post by willandrip »
Use the OEM part no. at the r/h side of the list.
A dash requires inserting twice in those numbers though e.g.
1WG-?????-??
Then google the number.....
Which of your gaskets were incorrect ?
snydes
100+ Posts
100+ Posts
Re: Gasket Kit
Post by snydes »
willandrip wrote:Use the OEM part no. at the r/h side of the list.
1WG-?????-??
Chain tensioner, cam shaft cover (was just a bit longer in one spot but using gasket sealer worked I think so far)
Those are what I know so far, I'll let you know if there's any more
Thanks,
ASnyder
willandrip
Level 7.0
Level 7.0
Re: Gasket Kit
Yeh, as Evilchicken stated earlier......the cam cover gasket failed.
The pic you put up of it was far from inspiring also
snydes
100+ Posts
100+ Posts
Re: Gasket Kit
Post by snydes »
willandrip wrote:Yeh, as Evilchicken stated earlier......the cam cover gasket failed.
Yeah the OEM one had no rubber piece in the center of 2 sides which I had to cut away for the cam guide.
Thanks,
ASnyder
snydes
100+ Posts
100+ Posts
Re: Gasket Kit
Post by snydes »
Evilchicken0 wrote:A ton quid is about right for a gasket set. When I used a pattern one in a cam cover it leaked, even though I used silicon to glue it in it wouldn't sit right it seems a couple of mm short. Then I used an OE and it was fine.
My cam gasket doesnt fit perfectly either, not sure if it leaks yet, where did you get the OE gasket?
Thanks,
ASnyder
Evilchicken0
Level 3.5
Level 3.5
Re: Gasket Kit
Post by Evilchicken0 »
E-bay ... I found one for £6.50 but had to wait a while.
This should fit
http://www.ebay.co.uk/itm/Yamaha-Fazer- ... 3aae41180e
FZR400RR 3TJ Bimota SB6
Witchboard
Re: Gasket Kit
Post by Witchboard »
I ordered the head gasket and cylinder gasket separately because I read they were different than the originals. The ones that came in this kit looked identical in material and shape to the OEM gaskets I purchased. Just in case anybody was wondering.
