Just fix a 750 FZR
Re: Just bought a 750 FZR
Very very nice, How did you resolve the fairing mounting issue, or did I miss that? Did you fabricate something on the OEM birdcage?
My FZR6 Rebuild
My FZR6 Rebuild
- shredex
make a fairing insert for the bottom of the tank that goes to the top of the subframe and back under the front of the seat.
then put a black or carbon plate in the space between the two subframe rails to hide the wiring.
looks alot better than I thought it would!
great job!
great job!
Chris,csofos wrote:The paintwork completed......
That's a spot i have to fill with something
This motorcycle is dedicated to the memory of my friends Jack. Most of you, probably remember the story....
Many could say that typing a dead man's name on the bike might be a bad luck. Not for me though. I think it's a guardian angel.
Phew piece of art or wot?
The infill I would make onto the front seat foam base and the panel in with the upholstery material.
If I dedicated my bike i would have put it in front, he has after all gone hopefully to a better place before you and sitting on his memory well is just not a way I would remember a pal :-} To each his own is what makes life interesting & far from boring for sure
Thanks a lot George. As for the name's position, i did it that way, cause i saw a lot of bikers doing the same. And because i feel him like an angel (you know, at my back). Anyway, that's my point of view. Thanks again Georgeyamaha_george wrote: Chris,
You are absolutely right. I forgot to mention that. I fabricate a new front mudguard. I'll post some pics on the next days. Thanks for the noteGenesis wrote:Very very nice, How did you resolve the fairing mounting issue, or did I miss that? Did you fabricate something on the OEM birdcage?
Your bike really looks assume. I agree with YG though, extend the front seat forward to close in that space, it will make a nice padded area for your legs to wrap around....... OO wait are we talking about a bike??csofos wrote:You are absolutely right. I forgot to mention that. I fabricate a new front mudguard. I'll post some pics on the next days. Thanks for the noteGenesis wrote:Very very nice, How did you resolve the fairing mounting issue, or did I miss that? Did you fabricate something on the OEM birdcage?
My FZR6 Rebuild
My FZR6 Rebuild
You should change the thread title to: "Just pimped out a 750 FZR"
Upgrades:
- shredex
here is what i was saying that you could do with that space you need to fill
and im not to sure about the moving the seat up idea...doesnt seem to look right
Well shred, i was thinking about the same. I'll make 2 pieces from polyester and place them exactly as you tag in the photo. But this can be done later. Now, i have to do other jobs, like put in function the bike and the electrical systems, plus the koso gauges. I have to make stable the rear brake caliper too. And many other jobs.shredex wrote:here is what i was saying that you could do with that space you need to fill
Thanks for your advise and the photo buddy
- Level 3.5
Re: Just fix a 750 FZR
Once again you have created an amasing bike.
Thanks a lot buddy!!! But, i 'll stop for August. A girlfriend is goming from Australia to visit me for 15 dayschefen2006 wrote:Once again you have created an amasing bike.
So every work on the bike has to wait for September. When i' m done with it, i 'll post new photos and a link with a video showing the bike in function.
See you all in a couple of weeks guys
- Level 3.5
well we are at the end off September now,so where is the video with you riding the bike?? I know you have been working on the Kawa ( another cool bike from "csofos dream garage" ) Any updates on this one???? I want to hear that you`v managed to fix the black box,the motor running,and the suspenders working and so on....
Have to finish the Kawa 1st. Then invloved with mine. Oooohhhhhh i'm looking forward the time i'll ride my 750 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!chefen2006 wrote:well we are at the end off September now,so where is the video with you riding the bike?? I know you have been working on the Kawa ( another cool bike from "csofos dream garage" ) Any updates on this one???? I want to hear that you`v managed to fix the black box,the motor running,and the suspenders working and so on....
f*ck, f*ck, f*ck!!!! The engine never started. I tried soooo many times. And finally i checked the cylindres compression. It was veeeeeeery low!!!! I opened the engine and i saw that piston rings (especially on 2nd and 4th) were off. The valve needed rubbing. All that was good, and something i could easily deal with... untill...... i saw the a crack on the 2nd cylinder. On the upper edge! Damn! Where to find a cylider and who's gonna give you one. And if all these shits have happend far now, imagine what else could be failed in this engine?????? So my opinion is to buy another engine.
I have a question though, and i want your opinion guys:
My fzr 750, as you all know, it's '87 model (similar to '88). Can anyone tell me if the 1000 same years engine fits in the 750's frame? Needing any modifications to fit him in? Someone told me that it fits like a glove. But this is one mans opinion. If anyone has an fzr 1000 '87-'88 model, can he measure the distances where the engine grounds to the frame. Then i'll compare them with my 750's to check what can i do.
