Problem at low revs
Problem at low revs
My 92 fzr600 gets all jumpy and jerky when I'm cruising slowly in first. It goes away once I get the toms up a bit but if just putting along it feels like it's trying to throw me off. Any ideas what the problem is? Please don't say it's the carbs
- willandrip
- Level 7.0
Re: Problem at low revs
By toms : I presume you mean rpm.rippinggnar wrote:My 92 fzr600 gets all jumpy and jerky when I'm cruising slowly in first. It goes away once I get the toms up a bit but if just putting along it feels like it's trying to throw me off. Any ideas what the problem is? Please don't say it's the carbs
A fzr engine is not designed for cruising at low rpm , keep the revs up above 3k; they were not built for pottering about.
It might be the carbs.
+1, these aren't trials bikes. The engines are designed to scream, and simply don't carburet properly below a certain rpm.
Check your chain tension; a slack chain makes it worse.
- willandrip
- Level 7.0
It was the "cruising" bit that got to me !
I nearly retched.
I nearly retched.
