95 fzr600 dancing tailight
Kenny two guns
Post by Kenny two guns »
Perhaps someone could shed some light on this dancing taillight. Also, was this a desired effect by PO or do you think I have a wiring issue of some kind? Happens from the moment I turn the key on.. I want this gone any suggestions would be appreciated..
http://s1172.photobucket.com/user/Kenny ... sort=3&o=0
1995 Yamaha FZR600
1992 Kawasaki EX500
thatkid
Re: 95 fzr600 dancing tailight
Post by thatkid »
It's a safety feature. Will give the drivers behind you something to notice. I would personally leave it but otherwise it's most likely some bulbs in there and a relay. I have many many taillights if you want a new unit instead.
Do YOU Scopper?
Kenny two guns
Thanks for your reply Thatkid. I considered keeping it but I have a feeling the local law enforcement wont care for a civilian with a constant flashing red light. They have this weird idea that flashing lights are for emergency personnel only. Plus I can't imagine its good for my battery.
1995 Yamaha FZR600
1992 Kawasaki EX500
DonTZ125
Moderator
Post by DonTZ125 »
Depends on the area, and the mood of the cop. Most don't mind a flashing brake light, but - as you say - a constantly flashing red light is likely to involve somebody else's flashing red lights ... :cop:
pefrey
Level 5.5
Level 5.5
Post by pefrey »
What's a dancing tail light? If it flashes only when applying the brakes I don't think there will be a problem unless you don't like it. If it flashes all the time, then I think you are going to have to correct it.
Kenny two guns
pefrey wrote:What's a dancing tail light? If it flashes only when applying the brakes I don't think there will be a problem unless you don't like it. If it flashes all the time, then I think you are going to have to correct it.
Dancing, pulsating, flashing whatever u prefer to call it.. As I said "it happens from the moment I turn the key on" and stays on. In addition the pattern actually changes when applying the brakes..
1995 Yamaha FZR600
1992 Kawasaki EX500
pefrey
Level 5.5
Level 5.5
Post by pefrey »
Yeah I am going to guess that's going to be a cop magnet. It sounds like some mod the PO did so I'd start tracing the wires from the tail light back to the source. I imagine you are going to find something that does not belong along the way. Unless it is the bulb itself, I'm not too familiar with ghetto fab. Sorry, couldn't resist. :cheers:
