need a new clutch
burns556
100+ Posts
100+ Posts
need a new clutch
Post by burns556 »
Any body got a preferred replacement clutch and springs? Gotta order one so help me out thanx
i like cookies nom nom
DonTZ125
Moderator
Re: need a new clutch
Post by DonTZ125 »
Reelrazor swears by OEM plates. OEM springs are also better unless you've SERIOUSLY powered-up the engine; aftermarket "racing springs" will just make your left arm hurt.
CrazySkullCrusher
100+ Posts
100+ Posts
Post by CrazySkullCrusher »
Oem. Kevlar plates can't be used with synthetic oils and so limits your options, and I've had guys tell me they wear out faster
96 fzr600. R1 body kit.
FZRDave91
Post by FZRDave91 »
you cannot go wrong with the OEM clutch setup
1991 FZR600 w/ YZF VR Upgrade, Twin Headlight conversion
1981 XS400 Cafe build.
Can't ya tell I like Yamahas?
thatkid
Post by thatkid »
CrazySkullCrusher wrote:Oem. Kevlar plates can't be used with synthetic oils and so limits your options, and I've had guys tell me they wear out faster
This statement is false. EBC is the only company that specifically states not to use their kevlar clutch with a FULLY synthetic oil. However, many people have done so with no issues using quality brands of synthetic oil.
But for longevity the OEM plates and discs are your best bet.
Do YOU Scopper?
CrazySkullCrusher
100+ Posts
100+ Posts
So....no real reason to quote me and then refute what I said.
thatkid
Post by thatkid »
Except that your statement was inaccurate about kevlar clutches...
Do YOU Scopper?
CrazySkullCrusher
100+ Posts
100+ Posts
I put a kevlar clutch from barnette in my xj600 last spring, ran full synthetic 10w40. The clutch would slip in the power band only if the motor was cold, thought it was really weird. Talked to the owner of my local shop, he said kevlar hates synthetic oils. I switched to conventional oil and after a few Weeks it went away. I wouldn't give advice on here without having personal experience in the matter.
SquadraCorse
Post by SquadraCorse »
I had an EBC Street Racer Kevlar clutch in my fzr and the thing slipped pretty bad in the power with Motul Synthetic. I recently put in the DP clutch setup and it's been great.
burns556
100+ Posts
100+ Posts
Post by burns556 »
Cool thanks guys for the help should I get a new clutch basket as well
CrazySkullCrusher
100+ Posts
100+ Posts
If there is excessive wear in the channels where the disks engage it would be a good idea. A repair manual will guide you through the inspection process.
DonTZ125
Moderator
Post by DonTZ125 »
If the price of a new basket makes your wallet throw up, you can extend the life a bit by carefully draw-filing the basket fingers to smooth out the grooves. Bear in mind that you ARE extending the life of an expired wearing part, and that the extra rattle-room caused by filing the fingers down will accelerate the wear rate, so start a penny jar for a replacement.
CrazySkullCrusher
100+ Posts
100+ Posts
I have bought baskets from salvage shops before that were still in decent shape. Unless you clutch up lots of wheelies or there's a million miles on the clock your basket should be ok.
