R6 VR mod
haunter
Re: R6 VR mod
Post by haunter »
get a pic from further away!
tommyj27
Level 9.5
Level 9.5
Re: R6 VR mod
Post by tommyj27 »
ask and you shall receive. i shot the first couple up close so that ppl could see detail; i know i like all the details!
haunter
Re: R6 VR mod
Post by haunter »
looks good
probably shoulda moved that dildo outta the 'trunk' for the pic though :whistle
bweight
Level 4.0
Level 4.0
Re: R6 VR mod
Post by bweight »
haunter wrote:looks good
JerryJerry
89 FZR 400
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
tommyj27
Level 9.5
Level 9.5
Re: R6 VR mod
Post by tommyj27 »
what can i say, it didn't quite fit all the way in the trunk. :mrgreen:
haunter
Re: R6 VR mod
Post by haunter »
thats a biggun!
I bought my fiance that same one for our anniversary :whistle
B.Shady
Re: R6 VR mod
Post by B.Shady »
These may sound like two dumb questions, but how do i check the voltage coming out of my new regulator and what should it be?
tommyj27
Level 9.5
Level 9.5
Re: R6 VR mod
Post by tommyj27 »
B.Shady wrote:These may sound like two dumb questions, but how do i check the voltage coming out of my new regulator and what should it be?
13.7-14.9 @ 3000rpm
Check out this flowchart, it walks you through diagnosing your VR. Print it out, grab your multimeter, and head out to the garage. A second set of hands can be useful too.
http://naes.afraid.org/hosting/Diagnosis/charge.jpg
95FZR600
Re: R6 VR mod
Post by 95FZR600 »
Is the YZF a direct swap?
ragedigital
4000+ Posts
4000+ Posts
Re: R6 VR mod
Post by ragedigital »
95FZR600 wrote:Is the YZF a direct swap?
If you have the 1994 and earlier old style, then no, it is not. naeslas had a good comparison to show the difference.
viewtopic.php?f=8&t=205
tommyj27
Level 9.5
Level 9.5
Re: R6 VR mod
Post by tommyj27 »
It's not too tricky though, the newer VR has an extra lead for ground. I just used female quick disconnects (the yellow 10-12ga ones fit perfect) to connect the wires (pics above).
I'd love to find the newer style wiring harness to replace the quick connects so that it looks a bit nicer. Does anyone know where I might find the harness? It's not listed on the fiche for the YZF/R6.
billy_awesome
Level 2.0
Level 2.0
Re: R6 VR mod
Post by billy_awesome »
yzf, r6, r1 whatever, they are all the same.
I just swapped out my stock fzr VR(2nd one i've installed)
Went to the wreckers and got a R1 VR.
Naeslas' instructions are great and it works great, you dont need to be a master electrician to install one. just know how to crimp some wire and attach blade connectors, took me 20minutes which included drilling a new hole in my frame because I have the airtech tail. easy as PIE
xavier911
Re: R6 VR mod
Post by xavier911 »
I have a 91 FZR 600. recently some douche bags tried to steal it and destroyed my ignition system. They also cut the ignition wires 2 try and hot wire the bike, the whole time not noticing the fluro yellow disc brake lock preventing it from moving. Well i got a new ignition system wired it up and turned the key.........nothing no power at all. I checked the battery and it has plenty of charge. I checked the fuses, they are fine. I even got a mate to get his multi meter out 2 find out where the power was and wasnt going, he was of little help. Any other possible ideas before i pay out the ass for a Yamaha dealer to fix it???
Any help would be massively appreciated.
Cheers,
Xavier.
zero9243
Level 8.5
Level 8.5
Re: R6 VR mod
Post by zero9243 »
lol
Upgrades:
CJD
Re: R6 VR mod
Post by CJD »
zero9243 wrote:lol
I must say this is an excellent reply :cheers: , but see mine :cheers:
xavier911 wrote:I have a 91 FZR 600. recently some douche bags tried to steal it and destroyed my ignition system. They also cut the ignition wires 2 try and hot wire the bike, the whole time not noticing the fluro yellow disc brake lock preventing it from moving. Well i got a new ignition system wired it up and turned the key.........nothing no power at all. I checked the battery and it has plenty of charge. I checked the fuses, they are fine. I even got a mate to get his multi meter out 2 find out where the power was and wasnt going, he was of little help. Any other possible ideas before i pay out the ass for a Yamaha dealer to fix it???
Cheers,
Xavier.
Please inform your insurance company.
Preferably have them take it to your local Yamaha dealer, failing that any reputable motorcycle shop.
HTH
