r1 body kit, how to remove fairings?
CrazySkullCrusher
100+ Posts
100+ Posts
Post by CrazySkullCrusher »
Just bought this bike and need to perform some maintenance, what's the best way to pull the lower fairing without killing it?
96 fzr600. R1 body kit.
zero9243
Level 8.5
Level 8.5
Re: r1 body kit, how to remove fairings?
Post by zero9243 »
Do you have the R1 airtech kit? The kits come without holes drilled so I am not sure how many screws you'd have holding it on. Best bet would be to get something soft under the bike so when it drops off it wont scrape. Or prop it up with a shoebox or something as you undo the screws. Or get a friend to hold it up as you unscrew it :-D
Upgrades:
CrazySkullCrusher
100+ Posts
100+ Posts
Well the lower is one piece, I'm not sure if I can kind of roll it out from under the bike or what.
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
Once it drops out, you can kind of rotate it out on the drivers right side of the bike
Upgrades:
CrazySkullCrusher
100+ Posts
100+ Posts
Ok that's kinda what I figured. I think I have some carpet remnants hanging around to put under it. Thanks guys.
