Need some help... I blew like 7 fuses... I was replacing the battery, but nothing was happening when i tried turning the key... Then i notice the green 30 fuse was blown... So I replaced it and as soon as it touched the metal it was blown again... So would try different ways to connect it like putting the fuse in first then connecting the hot or ground wire to the battery but to no avail the same thing, a blown fuse... Below I attached a picture so you know what fuse Im talking about... Please any suggestions on whats going on will be greatly appreciated... I have no idea, unless i need to replace the part that the fuse go in...
