Switching Octane from Regular to Premium is OK???
ggradio
Post by ggradio »
I bought my 97' fzr600 last month. On the first fill up I used Regular. Then after reading on here I saw a post about using different octanes for FZR's. My questions are, Should a sport bike use Premium? Is it ok to switch right from Reg to Prem?
:tks: Noob
1997 FZR 600R
Re: Switching Octane from Regular to Premium is OK???
Post by sweekster »
That's a subjective question. I run premium in my bike-mainly because that's what is stated in the manual. That withstanding, if your bike runs fine on regular there's not much reason to switch. There are quite a few people on this forum who run their bikes on regular with no issue. Others have bikes that won't run at all on regular-go figure. My old 600 didn't like it. Anywho you could go about running 1 tank of premium through and see if it runs better. If it does then there's your answer.
ggradio
Post by ggradio »
Thanks, I'll try some premium and see how it does.
1997 FZR 600R
Yial
Post by Yial »
I have a 1994 FZR 600, and I recently ran about 1,000 miles on regular, that being said, I use premium because why not? The bike only takes 2-2.5 gallons on empty for me.. so the difference in price is negligible, even with how much I've been running it. I just kind of figure, it's supposed to burn better and cleaner, and it's easier then cleaning the carbs.
Some of my friends (for example, the one who owns a '99 R6) run regular and haven't seen any problems.
I second just seeing what works best in your bike though. (And your wallet)
turbotom105
Post by turbotom105 »
the best performance on any piston engine will come from running the lowest octane the engine will take without detonation. Believe it or not there is more energy in regular gas then there is in premium gas and more power potential providing the engine does not detonate. A bump up in compression ratio or timing will allow the bike to realize the benefits of running a higher octane fuel but in the case of a stock timed and compression fzr your better off with the regualr gas
_Will_
Level 5.5
Level 5.5
Post by _Will_ »
per the sticker on the inside of your rear fender the bike was designed to take 90, I run 89 without problem on my 94 600
Guys,
to be fair the label regular & premium on this board is totally meaningless as different countries use different standards and additives. You have to check what yamaha says about octane and buy what ever gas that is in your location and watch out for ethanol etc in it.
DonTZ125
Moderator
Post by DonTZ125 »
The other issue is that some countries use MON, some RON, and some (RON+MON)/2...
ggradio
Post by ggradio »
So I filled up with a tank of 93 Premium. Rode about 50 miles and really couldn't tell a difference. I think I'll just stick with Mid-Grade. I'll have to look for that label.
1997 FZR 600R
