throttle cable question
just wondering, and i did search, why is there two throttle cables?
1994 fzr 600, 9300 miles, d and d slip on.
Re: throttle cable question
This is a safety feature that many bikes have. If the throttle return spring breaks on the carb, you can still shut the throttle with the two cable system. Some people get cheap or lazy or both and just run one cable to pull the throttle open.
Rotortech
Indianapolis, IN
[list]RaceTech Springs
R6 Rear Shock
FactoryPro Jet Kit
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
- kilika2
- 1000+ Posts
Yep beat me to it. I was going to say 1 push, 1 pull.
Makes more since to my engineering head to have 2.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Ok, thanks, the second one is not hooked up from when I bought it , but I will be sure to hook it up
- kilika2
- 1000+ Posts
The cable that goes on bottom is a pain to get into the guide. I have more luck getting it in first and then twist the throttle to get the other one in place and then putting it into the guide.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
yeah it look kinda hard to hook up but it might be easier with the tank off
- kilika2
- 1000+ Posts
+1 you can spin the throttle,on the carb body, with your hand and hook the cable end (I officially call it the cable barrel) into the back side of the throttle on the carb and then let it loose to get the other one. Then attach it all to the guide.ama11 wrote:yeah it look kinda hard to hook up but it might be easier with the tank off
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
