convertible bike stand?
I need to order a stand and discount ramps has one for 50. bucks that will convert to front or rear, spool or non spool . I believe its called the all in one. Any body have any knowledge of these? Also in the manual it looks like a bolt going up the fork tube on the left side of the fzr? Will this not leave the hole for the stand pins to grab the front end on that side? I cant look at mine cause I'm outta town working. Id like to order so it will be there when I get home and can start tear down. Thanks
97 FZR 600
91 KLR 650
91 KLR 650
Re: convertible bike stand?
I've just watched the video on their site http://www.discountramps.com/all-in-one ... -stand.htm
When converted to lift the front end, the holes in the bottom of both forks are used. Every stand I've saw advertised that lifts the front end in that way states "must be used in conjunction with a rear paddock stand" or something similar. The first time I used my front stand I didn't use the rear one, the bike was unstable for my liking.
Take your time before you buy, wait for other members input.
That's why they advocate the use of a rear stand in conjunction. It makes things pretty rock solid. The only stand you won't need a rear with is the kind that lifts from below the steering neck, not from the forks.mawler wrote:I've just watched the video on their site http://www.discountramps.com/all-in-one ... -stand.htm
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
That's what I meant, I always use both if I'm lifting the front now.blensen wrote:That's why they advocate the use of a rear stand in conjunction. It makes things pretty rock solid. The only stand you won't need a rear with is the kind that lifts from below the steering neck, not from the forks.mawler wrote:I've just watched the video on their site http://www.discountramps.com/all-in-one ... -stand.htm
So for 30 more bucks and they throw in another part with the wheels and then you have both the front and back stand. Both for 80 plus shipping. Seems like a decent deal for some cheap stands. Thanks for the responses I think I'll get it with the additional part to make 2 stands.
97 FZR 600
91 KLR 650
91 KLR 650
I have a set of Pitbulls stands. Even with their "pin" front stand, you need a rear stand to help stabilize the bike.blensen wrote:The only stand you won't need a rear with is the kind that lifts from below the steering neck, not from the forks.
