Today I jammed over to the local Ace Hardware to see if they had any steel flatbar and box tube... they did but it was a real limited selection. I found some flat bar for the rear tank mount but the box they had was too big or too small so Im gonna check out South Bay Metals... with any luck they'll have what I need.
I snapped a few more shots of the progress of the tail. Not a whole lot has happened just cutting and grinding more of the subframe to get it fit. Tomorrow Im gonna spend some time and finish cutting the lower rails off the fzr subframe and get the r6 subframe ready to be mounted. Obviously I gotta get that box tubing first. I really want to find a size box which the r6 frame can fit OVER that way it'll look WAYYYY cleaner.
Anyways heres a few pics:
This is the jig I made to bend the r6 subframe
Here the r6 subframe bent to match the fzr frame
Minus the fzr subframe
Front snapshot of what I had to remove from the front of the seat pan
Yo, has anyone used that vinyl spraypaint? My seat is all faded and I was just gonna blast it with some of that stuff.
