So i found this for sale locally , not trying to bite off modking because ive liked these style pipes ever since i seen them on a bike . But could i make this work and how much fab work am i looking at
they guy is askin 200 for it says its in perfect condition off a gsxr 600
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
My buddy at work today mentioned to me that my bike would look great with the exhaust under the tail. If I used the short can under the tail I dont think it would get that hot being titanium. Ill talk to my muffler man. What would you all think?
pimp- go for it man.. It doesn't seem like it would hard at all. The only problem i see is that if you start welding on pipe or bending, you're gonna damage the chrome.
95fzr600- what kind of pipe will you be using under the tail? The one that is currently on your bike?
'92 FZR 600 Airtech R1 kit \*/ 520 conversion \*/ 14F-47R gearing
The R1 has dual exhaust under the tail so I would have to look and see if its design is the same as the short can I have. If its shaped different then I could use it under the tail and just have the pipe run to mount it. When I get back from NY I will run it down there. In the mean time I will find a can to fit under the tail.
ok pimp, the pipes will work for sure. and $200 + is the going rate for a set of devil shotguns so the price is right. the mounting will most likely be alot closer than you think, you will probably need some exhaust couplers to cut and weld , or you may be close enough to just cut a slight angle on the end of the mid pipe and weld it to the header . either way , i would make sure it's welded to the header to eliminate any leaks.
Man this kid replys to me a week later tellin me he got what he was askin for it which was 250. I offered him 200 which was all I was willing to pay even though the 250 he was asking was well worth it also :if it fit slip on . Well I'm gonna continue to find another one just this one was 10 miles away from me ugh
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
