Weird tire help
shredex
Weird tire help
Post by shredex »
ok, the guy i bought the r1 front from, said I would need a new tire because the one on there was dry rotted.
I checked over it and found that it wasnt and there was no flat spots from sitting and the tire is only from 2004 and it has alot of tread left on it which is why i kept it.
Iv been riding on it since the swap and have had no problems.
BUT, when I looked at it the other day, (looked because I rubbed my hand on it and it felt wierd) I noticed that my tire bumps out in the middle giving it kind of a triangular shape...it makes no sense because its not like im riding on the sides of the tires constantly...I mean my brand new back tire is flat down the middle do to all the straight riding I do.
so anyone know what could cause the middle of the tire to be bumped out all the way around??
ghettomedic505
100+ Posts
100+ Posts
Re: Weird tire help
Post by ghettomedic505 »
i could get into a big explanation of what is causing and the end result would still be to tell you to replace it. so just replace it!!!! pretty much its old its coming apart possibly and its better to be safer
OH I THINK I DROPPED MY MONKEY
95FZR600
Re: Weird tire help
Post by 95FZR600 »
Didnt we already go through this with you on this same tire? :headscratch:
Buy a new one and be done!! :cheers:
mossy1200
Level 5.0
Level 5.0
Re: Weird tire help
Post by mossy1200 »
Excessive v shape is not good.Get new tyre and make shure you go with the correct size for rim.6inch rim up to 190 and 5.5inch up to 180.
shredex
Re: Weird tire help
Post by shredex »
its the front tire which is a 120, and its on a r1 rim which is 120.
i just hesitate to get a new tire because tire will be about $30 used, then $40 for shop to install...and iv gotta keep ahold of all the money i can...still about $1100 in debt and its way overdue
ghettomedic505
100+ Posts
100+ Posts
Re: Weird tire help
shredex wrote:its the front tire which is a 120, and its on a r1 rim which is 120.
dude totally understand the money issue but i work parttime at discounttire and if a customer came inb with a tire like that we would tell them to replace and could not air up or do anything else to it due to the possibility of it seperating and it having a blow out. I see this shit all the time and it always ends with it coming apart. plus if it blows on a bike think of the damage you and your bike would take
abs929cbrrr
Re: Weird tire help
Post by abs929cbrrr »
pay your debt off.......
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
Fizzinatorr
Level 6.5
Level 6.5
Re: Weird tire help
Post by Fizzinatorr »
Time to be responsible...getting into debt will kick your ass later on
mrfreeze5
Level 8.0
Level 8.0
Re: Weird tire help
Post by mrfreeze5 »
rep[lacing the tire is a lot cheaper than a severe visit hospital bill. Rubber gets old. Even if you had a brand new 0 mile tire that was 5 or 6 years old, you still need a new tire.
manveru
Level 3.5
Level 3.5
Re: Weird tire help
Post by manveru »
job?
tkclow
Level 5.5
Level 5.5
Re: Weird tire help
Post by tkclow »
shred, check BikeBandit and just get a new front tire and save yourself any unneeded poss. pain and suffering. We all want you safe, a front tire blowout is NO FUN!
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
shredex
Re: Weird tire help
Post by shredex »
im getting a used tire for $25...its my brother gets all of his tires...
then im driving up to brooksville to have the dude at suncoast cycles install it for $25...
