hi again ????? 1990 fzr 1000 brakes
are the front disc supposed to have a bit of play someone told me they are supposed have a bit of play they rattel a bit thats all but it stops great...
Re: hi again ????? 1990 fzr 1000 brakes
Are you saying the rotors "wobble"? If so no they aren't supposed to move.
- sbutler
Yes they are floating rotors & they should move on the rings.
S,sweekster wrote:Are you saying the rotors "wobble"? If so no they aren't supposed to move.
Yes you are right & wrong at the same time.
The discs are supposed to be bolted tight to the hub & not move BUT they are "floating" rotor types and move on their locking pins that join the rotor (the area gripped by the brake pads ) to its own fixing plate to self align within the brake pads.
If they do not move the pins should be thoroughly cleaned so there is uniform movement right around the disc.
thxs for the help guys
You are welcome :-}chrisfzr1000 wrote:thxs for the help guys
yamaha_george wrote:S,sweekster wrote:Are you saying the rotors "wobble"? If so no they aren't supposed to move.
HA...That would not be the first time!! Thanks for the save guys
No problem Sweekster we all watch each others backs here :-}sweekster wrote:yamaha_george wrote:S,sweekster wrote:Are you saying the rotors "wobble"? If so no they aren't supposed to move.
