can i put my signature picture beside the text?
match417
Level 8.0
Level 8.0
Post by match417 »
I've been trying everything i know with html trying to separate my signature with the text on the right side and the picture on the left. Is there any way to do this? Mods, is there a way? I just don't want my signature to be as long as it is. Who would know? Can I turn off the code to insert html? I tried playing around with the "disable BBCcode" checkbox, but I don't know exactly what that does.
cad600
Re: can i put my signature picture beside the text?
Post by cad600 »
Pull the picture into an editing program like photoshop, add the text, and save it all as a jpeg. Then load it here as one image.
match417
Level 8.0
Level 8.0
Post by match417 »
yeah, i've thought about that and done that before, but it always leaves the text slightly smaller or slightly larger than the other text, not to mention editing the text later on is a pain
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
match417 wrote:yeah, i've thought about that and done that before, but it always leaves the text slightly smaller or slightly larger than the other text, not to mention editing the text later on is a pain
do a printscreen on ur current sig and just move the text next to the pic
Upgrades:
