Oh also, the height at the end of the swingarm.
TK,thatkid wrote:I'm wondering if anyone can measure the axle dia. of the R6/R1 axle and the width between the sides of the swingarm. If someone can measure the distance between sides when it's unclamped that would be awesome. Thanks in advance for any help anyone can give.
A tape measure would work for all the measurements. Inside edge to Inside edge for the swingarm should be easy. The height at the back of the swingarm should be cake too. The axle, if you can wrap paper, wire, something that doesn't stretch around the axle until it touches itself then just measure that length. Then I can use those awesome geometry skills I learned to get the diameter.95FZR600 wrote:I have the spare swing arm but I dont have any calipers of any type to measure anything.
I think for most of those you wouldn't have to take the bike apart. Doesn't some of the axle bolt stick through the nut? The height could be measured on the bike and the tightened distance between sides could be measured and I could compare that to 95's measurement for untightened.old_school wrote:I'm your guy... as long as i don't have to take my bike apart...
thatkid wrote:A tape measure would work for all the measurements. Inside edge to Inside edge for the swingarm should be easy. The height at the back of the swingarm should be cake too. The axle, if you can wrap paper, wire, something that doesn't stretch around the axle until it touches itself then just measure that length. Then I can use those awesome geometry skills I learned to get the diameter.95FZR600 wrote:I have the spare swing arm but I dont have any calipers of any type to measure anything.
I appreciate it guys.
thatkid wrote:So that would make the axle 1.43" in Dia. I mean that sounds about right. Close enough for right now though for what I'm doing. Thanks man. I can slowly continue on with one part of the design phase!
Yeah, I mean the axle shouldn't change diameter anywhere along the line so it should be fine. If you can measure the end of the axle there at the nut for just a double check that would be sweet. As far as the height, I'm looking for the height of the swingarm where the sliders are for the axle. So like, on the FZR where the end caps would go for the axle adjusters. The end of the swingarm there is 2.3" tall or something like that. Wondering what it is on the R6/R1 swingarm. That first picture you posted shows the part I'm looking to have measured.old_school wrote:does it look like i measured it at the right spot?
George, I have no idea what it should be. I know the rear R6/R1 should be a pretty beefy axle since the front R1 axle is an inch if not a tad bigger. Still, I have nothing to measure myself so I don't know.yamaha_george wrote:TK,thatkid wrote:So that would make the axle 1.43" in Dia. I mean that sounds about right. Close enough for right now though for what I'm doing. Thanks man. I can slowly continue on with one part of the design phase!
a 36mm Axle ?????? bit fat for Yamaha Ducati yes ....................
TK,thatkid wrote:George, I have no idea what it should be. I know the rear R6/R1 should be a pretty beefy axle since the front R1 axle is an inch if not a tad bigger. Still, I have nothing to measure myself so I don't know.Y-G wrote: TK,
get it done this morning kid!thatkid wrote:Still looking for a width measurement from inside edge to inside edge? Anyone? Helloooo? Please...
