Page 1 of 2
FZ 750/FZ 1000 wheel swap
Posted: Tue Apr 07, 2009 1:26 pm
by 20Valves85
Re: FZ 750/FZ 1000 wheel swap
Posted: Tue Apr 07, 2009 1:46 pm
by cad600
Nice. We don't have a lot of 750 owners here. Then again, there are not a lot of 750 owner's period (at least compared to the masses of 600's and 1k's). I'm betting that you will need the 1000 swingarm to do this correctly. Just out of curiosity, is there a reason you are swapping wheels and keeping the 18" rim? Most people try to get rid of the 18" rim to allow for a better selection of rubber. As about the welding, I have no idea. But historically, Yamaha has kept the 750 and 1000 very similar so you might get lucky.
Post up some more pictures of the bike when you get a chance. We love pictures here. Plus don't forget to introduce yourself in the new member forum.
Posted: Wed Apr 08, 2009 12:41 pm
by 20Valves85
Cad600,
As far as the wheel size, the guy I bought the fork, swingarm and wheels from would only sell the set together. I figured the FZ 750 had a stock 16" front and an 18" rear and for the price it was worth it. The front end also had braided lines. We all know most of the braking is up front and the front end swap should be straightforward(same bearings and races on both bikes). Here are pics of Neale Bailey racing on an FZ with only the front end swapped out:
Posted: Sat Apr 11, 2009 1:56 pm
by cad600
Been thinking about this for a little bit. Obviously making a spacer/caliper bracket is a little too much for this. I'm assuming that since you got the wheel in there, the axle diameters are the same. Which caliper bracket are you using? The 750 I would think is way to wide for the 1000 rim as a rim for a 130 tire will be vastly different from a rim for a 160 tire. Is the 750 bracket the one in the picture? Do you have or can you find the 1000 caliper bracket? I'm thinking that 1000 brakcet might be the correct width to work with the wheel / swingarm combo. Or you might be able to machine one end down to the correct width. You would also need the spacer for the sprocket side as well from the 1000. All this is assuming the swingarms are the same width at the wheel axle point.
Posted: Sun Apr 12, 2009 10:29 pm
by 20Valves85
Made some progress and looks like I need the FZR 1000 shock and linkage. Found them Ebay for fair prices so the wheels, swingarm and fork should go on ok. Spent two days sanding and polishing the old V&H Supersport exhaust canister and got it looking ok. Going to try freezing water in two of the lower header pipes to push out a couple dents. Here's a couple pics of the canister from Saturday and today.
Posted: Fri May 08, 2009 8:57 pm
by 20Valves85
Some progress to report today, I've been trying different combinations of FZ 750 and FZR 1000 swingarms, shocks and linkages and have settled on the stock 750 swingarm and shock. I ended up "machining" the rear caliper bracket and have what is almost a complete setup for the rear FZR 1000 wheel. Some more tweaking and rounding up a spacing collar should do it. I tried an FZR 1000 shock and linkage but the FZ 750 frame ears were different and the linkage would not line up. The rear caliper brackets are identical between the two bikes and modifying it was the simplest way to go. I need to find(or make) the LH RR wheel spacer for the FZR 1000 wheel. Yamaha doesn't sell the part anymore(Part # 90387-171T6-00). The RH spacer was the same on the 750 and I have several of those. The LH 750 spacer is a larger diameter and I can get that one machined down if I have to but...$$$. Some pics:
Things just didn't want to fit. Simple solution works.
My milling machines...
Cut and grind...
Getting there...
Posted: Fri May 08, 2009 9:51 pm
by ragedigital
That looks really good. We don't see a lot of FZs on here, so I'm glad to have you. Hopefully we can attract some more since I know there are people out there with them.
Keep up the good work and keep the pics coming!
darrin
Posted: Mon Jun 01, 2009 8:49 pm
by 20Valves85
Posted: Tue Jun 02, 2009 9:59 am
by 20Valves85
Posted: Wed Jun 10, 2009 6:40 pm
by fznut
Hi there; ive got an 86 fz750 with original stainless headers; ive got a coupple of dings as well; never heard of the frzen water trick; would appreciate hearing about it; thanks
Posted: Wed Jun 10, 2009 7:45 pm
by 20Valves85
Posted: Thu Jun 11, 2009 1:55 am
I saw the comments about fuel tanks. I've got a well-massaged TZ125 tank (aluminum) that is in need of some loving attention, and I'm just wondering if I need to worry about work-hardening. A bang to make a dent, a shove to push it back - will it split on me? WIll it be so hard that the next time I skitter along in the middle of Allen's Corner at Shannonville, I risk it making like an R6 tank and exploding into flames?
Annealing is the obvious answer, but I can't say I've ever annealed anything, much less a mild Al fuel tank...
Posted: Fri Jul 24, 2009 10:19 am
by 20Valves85
After getting some help from a rider in England who completed the FZR 1000 swingarm swap onto an FZ 750, I gave the swap another try. After a bit of cutting and grinding last night I got the swingarm fit up with the FZR shock and linkage. Here are a few pics:
Swingarm, shock and linkage installed, still a bit more grinding to do to clean up and give plenty of clearance.
Prior to grinding off centerstand spring clip and material from both mounting ears.
After grinding, it all lines up. Discovered that the 750 linkage bolt is a larger diameter than the 1000 bolt. Used a rear engine mount bolt from the 750 (note the long bolt) that was the right diameter. I think I can have the 1000 bushing machined out to accept the 750 mounting bolt.
I haven't given up the idea of keeping the centerstand which is why I didn't just whack the whole lower ear off. I'll see today if that's a pipe dream or not.
More grinding to do to give clearance for linkage bolthead and nut.
Posted: Fri Jul 24, 2009 10:45 am
Looks promising.
Posted: Sun Jul 26, 2009 2:05 pm
by 20Valves85
