The calipers were cleaned thoroughly, but not rebuilt. Seller claimed only 8k miles on the bike. Stock R6s pads and whatever stock/OE equivilent FZR rotors. I bled the lines a lot IMO, and no air bubbles come out. MC seemed to be making pretty good pressure when testing it. I "back bled" the lines per the wiki write up, but now searching the R6 forums I see some slightly conflicting/confusing info:
The wiki states:
but then the R6 forum says to:pump (squeeze over and over) your brake lever 4 or 5 times, then squeeze the lever hard and open and close the top banjo bolt near the master cylinder, DO NOT let go of the brake lever with the banjo bolt or bleed screws open! Open and close it quickly, fluid squirts out, this is normal. Repeat this 3 or 4 times. Then do the same thing for the bleed screws at the calipers,
http://www.r6-forum.com/forums/showthread.php?t=160449Loosen the bleeder screw with the wrench, pull the brake lever all the way back to the grip, tighten the bleeder screw, and release the brake lever.
It seems like most of what I am reading says to open bleed screw, squeeze lever and hold, close screw, release lever and repeat. I intend to try this when I get home, but will it make a difference or is pump, squeeze, hold, open, close, release accomplishing the same task?
