tranny fluid?
cntryboy85
Level 3.0
Level 3.0
tranny fluid?
Post by cntryboy85 »
so this is going to sound like a dumb question because it does to me but i am confused. i don't know why i haven't thought about this. but where do i check the tranny fluid on a 95 fzr 600? if there is any i haven't checked or put any in and i don't know why i didn't think about it before. please help
GreyImport
Re: tranny fluid?
Post by GreyImport »
Engine and gearbox share the same oil.
Thats why u cant just use any oil as if it contains "friction modifiers" your clutch will slip.
Fine for cars ,not for bikes.
Look up "unit construction" and "pre unit construction" on wikipedia
1990 FZR250R 3LN1
http://2fiftycc.com/index.php
LiteTek Carburettor Seal Kits
blensen
Level 2.5
Level 2.5
Re: tranny fluid?
Post by blensen »
cntryboy85 wrote:so this is going to sound like a dumb question because it does to me but i am confused. i don't know why i haven't thought about this. but where do i check the tranny fluid on a 95 fzr 600? if there is any i haven't checked or put any in and i don't know why i didn't think about it before. please help
Yep the only fluids you've got are engine oil, coolant, gas, and brake fluid. Easy enough to keep track of eh?
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
GreyImport
Re: tranny fluid?
blensen wrote: Yep the only fluids you've got are engine oil, coolant, gas, ,brake fluid and beer. Easy enough to keep track of eh?
Fixed that for u....... :whistle
:yutugh2:
1990 FZR250R 3LN1
cntryboy85
Level 3.0
Level 3.0
Re: tranny fluid?
Thanks guys. That's what I was thinking but just wanted to ask to make sure before I blew my tranny
pnbell
100+ Posts
100+ Posts
Re: tranny fluid?
Post by pnbell »
and don't forget about the often over looked headlight fluid... :duh:
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
JasonRDfan
Re: tranny fluid?
Post by JasonRDfan »
pnbell wrote:and don't forget about the often over looked headlight fluid... :duh:
Lol, I was going to ask about the blinker fluid. We shouldn't make fun though, I sure did some dum things when I started working on bikes. I was to embarrassed to ask for help. Looking back at things I would have saved a lot of money! I guess he is doing the smart thing. Way better safe than sorry and broke.
cntryboy85
Level 3.0
Level 3.0
Re: tranny fluid?
This is my first bike been riding for less than a year. I have
worked on cars my entire life. And I know some bikes have oil and tyranny fluid. But if you saw that I said "this is going to sound like a dumb question. Because it does to me." Why would you feel the need to pipe up with a un needed smart ass comment?
reelrazor
Wrench
Wrench
Re: tranny fluid?
Post by reelrazor »
Cntryboy,
they are all just having a little fun with you, 'cause, you know what? they(we) have all been there.
The way it goes is two stroke bike engines require trans oil (no recirculating engine oil to do the trans too)..
and older (older tech that is) 'pre-unit' engines separate the powerplant from the driveline (Harley non sportster engines, british things, and early early japanese four strokes)..
ours (modern) bike engines are 'unit construction'...meaning shared engine and trans oil-usually with one common casting containing both (hence 'unit').
HD big twins and most early bikes had a primary drive connecting to a separate gearbox..sometimes the primary oil was shared with the engine, sometimes with the trans, and sometimes was it's own sealed unit using only it's own oil.
There ARE advantages to non unit construction...the harley guys get to alter their primary drive ratios, and can swap in a 6 speed gearbox to replace their old 4speed if they want to. I am hearing that there are now SEVEN speed(two or three overdrive ratios) HD transmissions.
AimCOTaco
Re: tranny fluid?
Post by AimCOTaco »
Blowin' Trannys is NSFW and belongs in the off topic and is a waste of time, get back on your bike cntryboy!
-Another smart ass comment brought to you by me!
Andy
1999 FZR-600
Bunch of 4-wheeled junk...not enough 2-wheeled junk
cntryboy85
Level 3.0
Level 3.0
Re: tranny fluid?
sorry was just having a bad day that day. and i am trying to get back on it...lol. but i leave for texas on vacation tomorrow for 20 days then come back and head to japan on the 7th of sept. hoping to have her rebuilt while i am gone.
pefrey
Level 5.5
Level 5.5
Re: tranny fluid?
Post by pefrey »
cntryboy85 wrote: Why would you feel the need to pipe up with a un needed smart ass comment?
Settle down there cowboy, nobody meant anything by it.
pefrey
Level 5.5
Level 5.5
Re: tranny fluid?
Post by pefrey »
cntryboy85 wrote:sorry was just having a bad day that day. and i am trying to get back on it
No worries we all have them. You can score some very cool FZR parts while in Japan. Personally I'd bring back an entire FZR400 3TJ in my luggage.
cntryboy85
Level 3.0
Level 3.0
Re: tranny fluid?
i wish...ima try to do a complete yzf motor/swing arm swap with R6 shot upgrade and wouldnt mind tryn to convert the gage cluster to electronic
pnbell
100+ Posts
100+ Posts
Re: tranny fluid?
Post by pnbell »
Yup, Just joking around with you! :cheers:
Honestly many years ago I was trying to figure out how to change the transmission fluid on an old Honda... :headscratch:
Good Luck with the Bike and all your travels!
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
