intake boots
cntryboy85
- Level 3.0
intake boots
i have a 95 fzr 600 3HE that i need intake boots for and am having a hard time finding boots and not paying $248.00 for them. does any one know of any other boots that would work on the bike. maybe newer boots wont be quite as expensive.
Re: intake boots
I can get them for about $125 I think.
cntryboy85
- Level 3.0
Re: intake boots
can you check and see if you can get them. right now i really just need one for the left side. i checked for leaks and it is the only one giving me problems.
Re: intake boots
i bought some that worked great from a site called "www.georgefixs.com" for $84.00 + $10 shipping; there are more available.
* Note: Loosen/Tighten the Vacuum Screws before you install them; Mine were torqued SO TIGHT that i spent an hour just trying to get them out and stripped every one!! If they weren't install on the bike already it would have be easier... So just a note.
http://www.georgefixs.com/servlet/the-7 ... AKE/Detail
Also when Removing/Installing one of the boots (the left middle one) its tight and you'll be pressing on one of the engine coolant pipes; the sealing o-ring on mine was so worn out that the act of pushing on the pipe cracked the seal and caused a leak... Consider yourself warned!
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
