1994 Failed Emissions
Posted: Mon Jun 25, 2012 4:00 pm
Hi!
Arizona is the only state that still does MC emissions and the EPA is slated approve to allow us to stop testing next month...
I just bought a 1994 fzr600. The bike runs great but I took the bike into the shop to have the carb's synced. I was told that the bike is running lean. The person I bought it from added a K&N Air Filter and a Yoshimura pipe but never jetted the carbs. They said they opened the jets all the way but it's still lean and might not pass. Well I took it in to emissions and it failed on Hydrocarbons(2200ppm allowed 1800ppm)... Now from what I know if you change the air flow you need to rejet to make up for the new air.. Well I just use it to commute and don't care for the mods, so I want to return to stock. Problem is finding a good pipe... My emissions is due in 5 days so I was wondering if just dropping in the stock air filter will restrict it enough to richen it up to pass or will I have to replace the pipe as well?
I have changed the oil and flushed the rad. I will be replacing the spark plugs tonight as well.
Also this might be a factor in the engine running lean but there is a dead spot in 5-6k range.
Any input would be welcome! Thank you.
