Brembo rear MC
Brembo rear MC
Pulled this off of a R1 to find out it is a direct fit. Its alot more solid and not as spongy as the Fzr MC.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
Re: Brembo rear MC
It's all in your head. The only difference is really the Brembo stamped on the side. The piston is slightly larger but not significantly enough.
Re: Re: Brembo rear MC
thatkid wrote:It's all in your head. The only difference is really the Brembo stamped on the side. The piston is slightly larger but not significantly enough.
You know she said the same thing. Lol
Thanks for the info nate.
sent from a portable leash
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
Re: Brembo rear MC
Actually, it's entirely reasonable to expect a better feel. 15-20 year newer seals, fresh fluid and a recent system bleed? You should HOPE a nearly-identical component would work better!
