UK MOT question
Siheinz
UK MOT question
Post by Siheinz »
Will the tester fail the rear tyre if it is squared off? tread depth is ok
new rear tyres are exspensive and budget is running dry!
Cheers Si
1990 FZR 600 UK Spec
taggy
Level 1.5
Level 1.5
Re: UK MOT question
Post by taggy »
i recon it will but will probably get an advisory for it. so long as the rubber isnt cracked and it has enough depth it should be ok. but im not a tester so i could be wrong!
Fzr400 3tj x2
'94 cbr 900rr
Yamster
Donating Member
Donating Member
Re: UK MOT question
Post by Yamster »
No,so long as there is 1mm all way across the tread,your fine.
Gizzard1533
Re: UK MOT question
Post by Gizzard1533 »
Depending on where you go, if its your regular mot guy then he may not say anything on the test he may just point it out to you unofficially. As long as there is the 1mm of tread and the rest of the tyre is fine you should be okay mate.
