98 fzr600 dies/ sputters / sucks
Posted: Sat Feb 25, 2012 9:33 am
by bobowbob
its hard to get the bike to start and when it does it dies as soon as you put it in gear. i rode the bike once and it kept dying i had to turn it off and back on
Re: 98 fzr600 dies/ sputters / sucks
Posted: Sat Feb 25, 2012 7:07 pm
Sounds like you have a few things going on there. The hard-to-start could be carbs, or it could be tight intake valves - insufficient clearance means the valves don't seal, you lose cranking compression, and the bike doesn't start. The "shuts off immediately" could be carbs (again), improperly adjusted clutch, or a bad connection in the safety system (probably the side-stand switch).
Pull, strip and clean the carbs, including a bench synch.
Adjust the clutch.
Check the valve lash.
Check the function and security of the sidestand switch and connector.
Should take you a lazy weekend with a friend and a few cold beverages of choice.
Posted: Sat Feb 25, 2012 10:59 pm
by bobowbob
i cleaned the carbs, tuned them, bypassed the kickstand switch, now it just dies on the interstate but runs good threw town?
Posted: Sat Feb 25, 2012 11:02 pm
THAT is a clogged tank vent. Pull and clean the little passages in your gas cap.
Posted: Sat Feb 25, 2012 11:31 pm
by bobowbob
what if it has a r6 tank
Posted: Sun Feb 26, 2012 12:36 am
Same thing - the issue is the vacuum being drawn down, not the shape of the tank.
Posted: Sun Feb 26, 2012 12:59 pm
by bobowbob
ok vacuum lines are cleaned and still doing it, its almost like its the coils. i was reading about swapping the coils and i noticed mine are not stock but not escort or that type of coil?
Posted: Sun Feb 26, 2012 7:12 pm
by bobowbob
problem fixed it was 2 crossed wires. wow this bike runs!!!
Posted: Sun Feb 26, 2012 8:45 pm
by cowboi
Crossed wires???
Do you mean coil wires or something else.
Posted: Sun Feb 26, 2012 10:15 pm
by bobowbob
spark plug wires
