VMAX calipers
Posted: Tue Jan 03, 2012 4:25 pm
has anyone verified that the 09 vmax 6 piston calipers fit the fzr 600. from what ive read the bolt holes are 100mm center to center and that they are a direct bolt on for the fzr 600.
i found this on a vmax forum
'' The R1/R6/Warrior NON-Radial calipers are all direct bolt on's for 93-07 Vmax's. If the bolts are through the side into the fork then it's the same. The radial (monoblock) calipers have the bolts passing downward into the fork and will not fit.''
