has anyone verified that the 09 vmax 6 piston calipers fit the fzr 600. from what ive read the bolt holes are 100mm center to center and that they are a direct bolt on for the fzr 600.
i found this on a vmax forum
'' The R1/R6/Warrior NON-Radial calipers are all direct bolt on's for 93-07 Vmax's. If the bolts are through the side into the fork then it's the same. The radial (monoblock) calipers have the bolts passing downward into the fork and will not fit.''
VMAX calipers
VMAX calipers
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
Re: VMAX calipers
Only one way to find out. You might want to source a master cylinder to go with them if they fit.
Re: VMAX calipers
Doesn't appear that is the case. All of the images I have seen for "2009" models have the radial (monobloc) calipers.
Re: VMAX calipers
yes i see now. found a good pic of the front endragedigital wrote:Doesn't appear that is the case. All of the images I have seen for "2009" models have the radial (monobloc) calipers.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
