Greetings, all. Well the issue is that my FZR 600 gene. 92, after two years of no use, I have decided to return it to use and removed the coolant cap, it overflows through the mouth. What may be causing?. The motorbike was started(pulled up) in due time and the refrigerant made new. As always thanks and be careful outside.
(That's as good as the Google translator could do - rage)
