Spark plug boots..........
I know the spark plugs that are called for on these bikes are resister type, the plug boot is also a resister type, my question: is there supposed to be this much resistance in the system? Seems to be a bit of over kill. trying to trace down weak sparks. I have trimmed back the wires to get to fresh inner wires, done a continuity check on all wires...and have found one of the boots to have a OPEN resistance.
90 fzr 600 former track bike put back on the street / 09 gsxr 600 / 81 Yamaha xs 1100 / 82 Suzuki gs 650g / Honda 07 VTX. You never see a motorcycle parked outside a psychiatrist's office.......
Re: Spark plug boots..........
That's usually a good time to replace that boot ...
Yeah 10k ohms is overkill, NGK do a replacement 5k plug cap (boot) which is fine. However I opened my caps and replaced the faulty resistors with a short length of 3 mm welding rod, after all the resistors are only there to help reduce radio interference nothing more.
HTH
HTH
Most things can be fixed "stupid" is unfortunately beyond repair
Thanks Lamer.....was thinking of going with copper dowel rod cut to fit.
Yeah coat the dowels with dialectic grease then, Roberts ya movas brover (in English) Bob's your unclebrcree wrote:Thanks Lamer.....was thinking of going with copper dowel rod cut to fit.
Toooo cool Lamer............hay tell me.....when one calls someone a "Bazzah" what does that mean? I know a "lemon Squeezah" is a Geeezzah..
