I began running through the tests for the VR from the archives. Seems my charging system is at 13.7V at the battery while idling (using choke - not sure if this throws off test), but when I choke it up to 3000 RPM, it dips down to 13.4V. I checked the amp loss by removing negative wire from battery and testing wire to beg terminal, it showed no amps. I didn't get past that part of the VR test.
Also, I notice a small dip in The neutral light when I pull the brake lever. Is this normal?
The bike seems to be idling a little rough. Not horrible, but not smooth either. I tried adjusting the idle to 1000 RPM this morning, and now at about 1200. Not sure if either seems great. What is standard. I didn't see it in the manual - but searching it on my phone is tough
Any help is much appreciated.
Scott
