jet kit now wont start
Posted: Fri Sep 30, 2011 10:16 pm
i just did a dynojet stage 1 jet kit now my bike wont start getting spark any ideas?
That pod tuning how-to does not describe how to run pods without rejetting. In fact, the author of the piece states that he's running 110s. I'm presuming they are Mikunis and, if so, are one step up from stock. Small upsize yes, but an upsize nonetheless. Judging by his pilot screws only being 2 1/2 turns out (3 is stock), I'm guessing he's at a fairly low altitude so it seems logical that 110s (by my source, roughly equal to DJ's 118s) would work for him. Anyway, the whole point of this how-to is to regain (allegedly) the low to mid-range torque that is typically lost when running pods by extending the length of the intake tract - Not to overcome any type of outright barrier which presents itself from improper tuning. I'm not entirely convinced that the solution is this simple. However, I may have to try it out firsthand with the YZF motor so as to not have to muck with the airbox fitting in the 400 frame. I digress...Nik wrote:Hi,
seems Y-Geo's write up on how to install pods WITHOUT re-jetting went un read, by you at least., suggest you read it up and follow the advice and it should all work very nicely (mine does :-}
I have to disagree here. If I'm understanding your post correctly, you're saying that in order for the bike to rev past 6500, you have to have the intake runners in place? My 600 had pods on it when I bought it and that thing had NO problem revving all the way to redline. The bike was fairly anemic until the tach swung up to 9K. At that point however, she screamed like a banshee and got the hell out of Dodge in a hurry. So regarding the OP's "brick wall"...there's something else going on there. The bike not wanting to rev high is a typical symptom of the charging system not working properly (aside from a couple other possibilities - clogged main jets (fuel and/or air), main and starter jets being inadvertantly swapped, ???.)Nik wrote: "the bike sounded like it hit the limiter," is why pods without the tubes do not work properly !
He said he went from 106 to 118 on the mains. Since Mikuni does not have a 106 size main jet (that I'm aware of), I'm assuming he's referring to Dyno Jets. In that case, DJ's 106 mains are roughly equivalent to Mikuni's 100s (stock is 107.5)!Nik wrote: you may need to go back to the original jets with pods & tubes as it is now so rich through out the carbs range that it may foul the plugs
I don't think my comments were off mark at all. I responded to specific comments that Nik made. The only thing that was off-topic was my skepticism of the intake runners being the solution to make the bike easily tuneable with pods (hence my digression). For the record, I did NOT say it wouldn't work at all. In fact, I said that I might even try it just to prove or disprove it to myself. I'm not claiming to be an expert on the subject but I just think there's more to it than extending the intake tracts. I'm an audio engineer and a drummer so the reason for my skepticism is that I have some understanding of how frequency waves work and how the size of an acoustic chamber (of any kind - airbox, drum, beer bottle...) has a direct effect on how the frequencey waves inside the chamber behave (not to mention the direction and speed the waves are travelling). Those airboxes have a specific internal shape and the air flows in a particular way so I just think the solution is a little more complicated than what's being proposed. Again - I'm not an expert but I'm also not talking out of my posterior (I hope I'm not coming that way). If there is more first-hand anecdotal evidence of this working really well, I'd love to hear it because I'd really like to avoid having to deal with the airbox if I go ahead with my YZF / 400 hybrid.yamaha_george wrote: Brandon,
Your comments are a little off the mark. Nik is quoting from his experience (I know because I was there) as his bike was also podded and and i would say coughed along rather than ran cleanly. At 6-7k rpm it would hit the wall stutter/cough/ clear its "throat" and then scream from 9-10k onward.
The hole at 6-7k is caused by the fact that the flat inner face of the K&N causes "reflections" which disturb the air flow, ie the inlet tract has been shortened by the filters end cap
I'm not questioning anybody's experience here. I simply responded to comments that seemed counter-intuitive to me. Does it make sense to you that the bike should run fine with pods and jets that are smaller than stock (WITH a higher flowing exhaust)? I know you said that bikes in other parts of the world may have different specs than the U.S. models but I think, on average, the atmospheric conditions are even enough around the world for Yamaha to justify not putting different sized jets in the FZR600 depending on which market it's going to. Besides, I even mentioned that the author of the pod how-to is probably able to run the 110s with pods due to being at a much lower altitude. That, along with the pilot screws being where they are, is a logical deduction. Hence, my comments regarding this point.yamaha_george wrote: As for "allegedly" both Nik & I made a bucket of money back in the late70's & early '80's with fri/sat night street dragging and the gambling that took place using various bike I prepared for he and I to ride.
Nik paid for his dental practice and I my estate with just the ext tube trick (and other bits & pieces :-}
As for Nik's advice to go back to scratch with the original jets in the original PO statement he said the bike ran poorly and after jetting not at all. Logic suggests it is better to go to something that works even very poorly than to tune an engine that is not actually firing (That would be a neat trick).
As for Jet sizes not being standard neither Nik nor myself have US spec bikes so the fact the PO bikes Previous owner had changed jets would be unknown to us both being "off shore".
As for the HOW-To original author going up a size on jets that is what made his bike work where he is., from 30 years of doing this nonsense I have found that the increased air flow actually make the carb work near to its optimum and that in 90% of the cases I had to DROP a jet size on main and lean the needle a tad.
I sincerely try to live by this mantra as well. However, in some cases, it's acceptable to use some logical deduction and related (although not direct) experience to come to some conclusion. If the conclusion is wrong, it will at least have sparked a discussion which hopefully can benefit everyone.yamaha_george wrote: Nik like myself will not give advice unless it is from our OWN experience which as I said he has known what I do since he first pulled my eldest kids tooth as his first patient fresh out of Dental school some 30+ years ago.( Nik, sorry to give your age away LoL)
as for experiences with anything YMMV
Our way or the highway? I think you'll find plenty of examples of people on these forums who use pods without tubes/stacks and achieve their performance goal. I respect experience, but I also respect those who find new ways to deal with old problems.Nik wrote:" after 30 odd years of doing this I am satisfied it works" if that is not good enough "If there is more first-hand anecdotal evidence of this working really well" then basically Y-G & I are agreed we are wasting our time on this thread.
Yes. That is what the how-to is referring to. Read it and it should be apparent to you.floridafzr600 wrote:thats just the part the stock box uses to mount to the carbs right?
Using the airbox's rubber boots (stacks) with pods or using the complete airbox is really the same thing. The only difference would be individual filters on each carb instead of one larger single one shared by all.fzrbrandon wrote:The tuning will still require a decent amount of fiddling to get right (i.e., nowhere near as straight-forward as it is with an airbox). However, as George, Nik, and Darrin have suggested, give the intake runner mod a shot and let us know if that helps.
I don't know. I think there's someing to be said about the enclosed space of the airbox and the fact that it is essentially a tuned chamber as opposed to an uncontrolled, wide open space (such as it is under the tank cover). I'm seriously wishing I didn't sell my pods now because I'd like to have been to try this on the "YZF motor-in-FZR400 frame" project (if it ever gets off the ground).ragedigital wrote:floridafzr600 wrote:thats just the part the stock box uses to mount to the carbs right?Using the airbox's rubber boots (stacks) with pods or using the complete airbox is really the same thing. The only difference would be individual filters on each carb instead of one larger single one shared by all.fzrbrandon wrote:The tuning will still require a decent amount of fiddling to get right (i.e., nowhere near as straight-forward as it is with an airbox). However, as George, Nik, and Darrin have suggested, give the intake runner mod a shot and let us know if that helps.
I used the stock airbox with a K&N filter, DJ130 mains, V&H Supersport exhaust and the bike never had more power or ran better. It took a lot of tuning, testing, etc..., but that's to be expected.
Good luck!
