Jet sizes
Jet sizes
I did the pods in anticipation of a tank swap, which now is off the agenda. It's running decent and has some good high end power, but it's just not the same as my airbox.
I'm going to use the Flo-Commander still.
I was wondering what size jets people are using? I'll have a full yoshi exhaust with a half yoshi can and a K&N drop in. I'm going to grab the 4 sizes for $30 from DJ since I only need the jets and was unsure of which 4 sizes to shoot for.
Oh, my original ones were 128's when I bought it w/ the airbox and it ran way to rich. I'm pretty much starting from scratch.
'92 FZR600
Lots of Powder
Lots of Powder
Re: Jet sizes
How do you plan on using the airbox with the flo commander? I thought on their site they say pods are required? Just drill holes through the airbox? You'll probably have to get longer tubing at the very least.
On that note, I thought I'd mention that with my pods i've noticed the same thing, and i get worse gas mileage. Still trying to tweak the flo commander and the jets though.
Upgrades:
Re: Jet sizes
DB,delvryboy wrote:I did the pods in anticipation of a tank swap, which now is off the agenda. It's running decent and has some good high end power, but it's just not the same as my airbox.
Pods do NOT require re-jetting of the carbs If the mod is done correctly with the inlet tract being left as standard.
I posted the way to do this along time ago:-
http://fzronline.com/wiki/doku.php?id=pod-tuning
Re: Jet sizes
d'oh, i remember seeing that post from you before YG, i'll have to find my stock airbox wherever it is and grab those parts out of it
Upgrades:
Re: Jet sizes
although, YG, you should still be able to get the carbs tuned correctly if you get correct jet sizes right?
Upgrades:
Re: Jet sizes
Z,zero9243 wrote:although, YG, you should still be able to get the carbs tuned correctly if you get correct jet sizes right?
theoretically yes, but if what I did in the past is right you will be nearly my age when you get it right & have knuckle scars of a Thai boxer <BG> to prove it
Re: Jet sizes
The only jets I have now are 130's. I could mount the fc inside the airbox or outside and run an inlet tube to the inside.
Really though, I don't have much reason to stay with the pods, so.....
WhIch 4 jets should I get? I was thinking 116, 118, 120, and 122.
'92 FZR600
Lots of Powder
Lots of Powder
Re: Jet sizes
hi,
if you are reverting to air box ,clean the filter, invest in NEW plugs go out test the bike AS IS then see where it is rich / lean and pick your jets to suit.
Re: Jet sizes
I was thinking that geo, but I figured the 130's would definitely be rich.
'92 FZR600
Lots of Powder
Lots of Powder
Re: Jet sizes
In the WIKI there is a listing for what others have as working jetting in various bikes that might give you a base line as to where to start looking :-delvryboy wrote:I was thinking that geo, but I figured the 130's would definitely be rich.
http://www.saltmine.org.uk/fzr/fzr-carb-settings.html
